MAZDA - 616 Capella (S122A/12ARE) 1970-1978
Iniciado por Kaizen, 06 de Maio de 2005, 03:34
http://me.a-spec.ca:6112/a/Mazda/PastCars/Piston/70Capella/616.JPG" style="border:0;"/>
Series 1 Capella can be distinguished by its rectangular front headlights an both 1600 and Rotary models. The RX-2 had the round tailights similar (probably interchangeable) to the R100. The RX-2 had " RE " rotor shaped badges on the front guards, the grill had a large " RE " badge and also a slightly different rotor shaped badge in the very centre of the grill. On the glovebox lid you will find " Capella " on the piston models and the rotary models also have a red " RE " after it. The RX-2 interior also had a centre console standard, fold down armrest in the back seat, tach, dash, and some other options like electric aerial ... etc. Take a look in the original manual to see some of the options ! Also the rotary models came with the ignition key steering wheel lock where as the 1600's did not. Series 1 models will have a built date between 1970 and 1972.
http://rotary-world.de/assets/images/616/616-14-1.jpg" style="border:0;"/>
Series 2 Capella was very similar to the Series 1 but had twin round headlights on both piston and rotary models. They were built between 1972 and 1973. Everything else stated for Series 1 should hold true for series 2. The series 1 and 2 both came out with a 12A twin distributor engine and 4-speed gearbox. These motors saw the starter motor up on the top and the slave cylinder down the side. The engine mounts to the crossmember using brackets attatched to the front side plate of the engine. The brake master cylinder on the RX-2 models is remotely mounted on the right hand strut tower for both series 1 and 2 models, presumeably to keep the cylinder away from the heat of the exhaust.
http://me.a-spec.ca:6112/a/Mazda/PastCars/Piston/70Capella/75capela.JPG" style="border:0;"/>
Series 3 Capella had the same twin round headlight front as the Series 2, but had very different hexagonal taillights. I believe this was to fall in line with some Japanese compliance at the time. Another thing is that for the first time the tail lights for both 1600 and rotary models were the same, with the RX-2 getting a Rotary Engine badge on the rear panel. The rear bumper was also quite different to make place for the reflectors and new under bumper mounting position for the number plate. I believe the badge on the front grille was also now " Rotary Engine " and the re badging on the front guards was discontinued. The " Capella RE " on the glove box was also discontinued. Another change for the Series 3 was the bonnet now instead of having the real vents in the bonnet had a different looking bonnet with larger fake vents more towards the centre of the bonnet. The RX-2 also had a major change, recieving the new single distributor 12A, which mounted to a slightly different crossmember which allowed the front type mounts we are used to, that bolts to the front cover. On the front guards the indicator lens was much larger and more rectangular than the Series 1&2 side indicator. The interior also received some major changes with a totally different dash and instument layout, no chrome rimmed tacho http://www.ezboard.com/images/emoticons/frown.gif ALT=":(">   ....., also the dash pad was a different shape, with a raised section in the centre, similar to the coupes? I believe. The fuel tank on the Series 3 has 1 less mounting hole than the series 1/2 but is still interchangeable. The front sway bar now had split pins to ensure the nuts don't screw off, and the rear axles had a locator for the centre of the rim bolted to the end.
http://rotary-world.de/assets/images/616/616-13.jpg" style="border:0;"/>
Series 4 Caqella had the same rear tail lights as the Series 3, again on both piston and rotary models. The front styling changed dramatically though with a different, more pointed bonnet, different front guards, and a three piece front bumper bar. The twin headlights remained as did most of the other features of the Series 3. Series 4's have no reflector on the rear quarter underneath the capella badge, and the interior for the first time saw retracteable seat belts. Also if your petrol filler lid is rusted out like most are, get a series 4 one as they are single skinned, so don't rust easily and are lighter too. The series 3/4 RX-2 (not sure if the piston ones are the same...) also had their steering box relocated rearward significantly (like 100mm) for increased exhaust manifold clearance, so if your thinking about installing a 12A turbo http://www.ezboard.com/images/emoticons/smile.gif ALT=":)">    or similar this might be something to consider when buying. The RX-2 is most distinguishable under the bonnet, all models had the twin coil brackets near the left hand strut tower, and most importantly S122A xxxxxxx chassis number (rather than SNA on all piston models), and also check the number stamped into the body matches the two plates rivited to the 'removeable' black cover panels. The rotaries also have different gearbox crossmembers and corresponding mounting points on the chassis!, as well as heat shielding for the exhaust attatched to the underside of the body. In the boot of the rotary models you will find no spare wheel well, (the spare actually takes up space in the boot). The extra room underneath the car was needed for the larger fuel tank on the RX-2 and also for the large rear muffler. As for brakes the rotary and piston models are virtually the same, the front brake calipers are different make but use the same brake pads, and are only single piston also, use the same discs, so they are virtually identical, or wouldn't have any increased braking ability anyway.
http://rotary-world.de/assets/images/616/616-01.jpg" style="border:0;"/>
The car was also known as the 616
Lifespan: 1970-1978
http://rotary-world.de/assets/images/616/616-10.jpg" style="border:0;"/>
Dimentions: 4150×1580×1395
Weight: 950kg
http://rotary-world.de/assets/images/616/616-15.jpg" style="border:0;"/>
70HP@5000rpm
92PS@5800 13.2kg/m@4000RPM
Motors: 1490 S4 OHC - 1586 S4 OHC - 1769 S4 OHC
Top Speed: 150 km/h
0-100: 13s
Efficency: 26 MPG
Weight: 1005 kg
http://rotary-world.de/assets/images/616/616-09.jpg" style="border:0;"/>
And it was also offered with a Rotary 12A engine
http://me.a-spec.ca:6112/a/Mazda/PastCars/Rotary/70Capella/12A.JPG" style="border:0;"/>
Edited by: http://p086.ezboard.com/bamigosdosjaponesesantigos.showUserPublicProfile?gid=umtali>Umtali at: 28/10/07 0:11
kombota
http://www.laffey.co.uk/mazda/mazda616.php" target="top">Informação Técnica
Cumpshttp://www.deephousepage.com/smilies/thumb.gif ALT=":[fixe]">
ENCONTRO NACIONAL AJA DIA 9 DE MAIO NA FIGUEIRA DA FOZ . http://rviper.no.sapo.pt/AJA/Ficha%20de%20Inscri%E7%E3o%20Nacional.doc" target="top">INSCREVAM-SE
kombota
http://escortmk1.no.sapo.pt/616/1.jpg" style="border:0;"/>
http://escortmk1.no.sapo.pt/616/2.jpg" style="border:0;"/>
http://escortmk1.no.sapo.pt/616/3.jpg" style="border:0;"/>
http://escortmk1.no.sapo.pt/616/4.jpg" style="border:0;"/>
http://escortmk1.no.sapo.pt/616/5.jpg" style="border:0;"/>
http://escortmk1.no.sapo.pt/616/6.jpg" style="border:0;"/>
Antena Electrica!!! Muito porreiro.
