DAIHATSU - Consorte (1969-1977)
Iniciado por blardY, 11 de Agosto de 2007, 04:19
Marca: Daihatsu
Modelo: Consorte
Carroçarias: Sedan (ou Coupé? ) de 2 e 4 portas
Modelo antecessor: Daihatsu Compagno
Modelo sucessor: Daihatsu Charade 2 portas e Charmant 4 portas
Dimensões: 2 portas / 4 portas
Entre eixos: 2160 mm  / 2260 mm
Comprimento: 3690 mm  / 3790 mm
Largura: 1450 mm  / 1530 mm
Peso: 700 kg  / 755kg
Capacidade do depósito: 40 l
Motor: 4 cilindros de 8 válvulas, montagm longitudinal
Cilindrada: 958cc / 1166cc a partir de 1971. Motor Toyota
Diametro x curso:  / 75.00 mm × 66.00
Taxa de compressão: 9.00.1
Potência: 52cv ás 5400rpm / 63.0 bhp ás 5800 rpm
Binário: 76NM ás 3800rpm / 90Nm ás 3200 rpm
Vel. Max: 140km\h
Tracção: Dianteira
Caixa: 4 velocidades
Jantes: 4J X 12
Pneus: 155 R12
kombota
#1
The Daihatsu Consorte was a small sedan sold by the Japanese automaker Daihatsu from 1969 to 1977. It was based on the Toyota Publica, and it's name, meaning "consort" in Italian, reflected Daihatsu's newly established affiliation with Toyota. It replaced the Compagno as Daihatsu's bigger sedan.
Initially, the Consorte was available only as a two-door sedan and with Daihatsu's own 1.0-litre engine. In 1971, Publica's 1.2-litre was added to the range. In 1973 a four-door sedan version joined the lineup, only to be dropped for 1974, with the launch of the Daihatsu Charmant. The 2-door was superseded in 1977 by the Daihatsu Charade
http://en.wikipedia.org/wiki/Daihatsu_Consorte
Especificações Sedan - http://www.carfolio.com/specifications/models/car/?car=115984
Especificações Coupe - http://www.carfolio.com/specifications/models/car/?car=116050
Nelson
kombota
Citação de: kombota em 10 de Dezembro de 2008, 15:30
Nelson
kombota
#3
